-   -   SMALL BLOCK EXHAUST MANIFOLDS (https://www.racingjunk.com/forums/showthread.php?t=29748)
nan 01-31-2011 01:11 PM
Does anyone know if the 5.7 (Tahoe etc.) exhaust manifolds will fit a 350 in an S10? Just got the truck and as far as I can tell its a stock motor except for intake and carb. It is Hedman headers that are 2 pieace both sides, leaks a little at the point where they slide together. I know the ram horn won't work the Tahoe look like they would. Any ideas? THANKS!!!!
bluedawg357 02-03-2011 09:19 PM
If they are leaking @ the collector you can either run thick aluminum or get the inserts that go between the collector & exhaust flanges. Dont know about the fitment of the tahoe manifold. :twisted:
