-   -   sugguestion on building 434 chevy (https://www.racingjunk.com/forums/showthread.php?t=29749)
smokinsmallblock 01-31-2011 02:41 PM
i planing on rebuilding my 434. tryin to get max horsepower to any1 have any good combination
TS1955 01-31-2011 05:19 PM
A lot will depend on what heads you are going to run. Will they be 23, 18,
15 degree? Now I have a 23 degree 434 that is 721hp. It has Brodix Track 1 CNC 227 heads, HVH intake, 15:1 compression, and a 930 cfm Holley, Dart Little M block & Comp Cams cam.
TS1955
hammertime 01-31-2011 05:44 PM
Re: sugguestion on building 434 chevy
What type of head are you looking to go with ?
and type of budget ?
fast75vega 01-31-2011 06:14 PM
434ci sbc pro top heads...it has a 4/7 swap 675 lift cam.......950 holly carb (running really rich too)...... got it in a vega with 430 gears and consistent 9.5's i the quarter
cncmotorsports 01-31-2011 07:04 PM
Depending on your budget, we have kits that will make 700-750 horsepower.
smokinsmallblock 02-01-2011 04:43 AM
i have 23 dart pro1 heads 215, 205vavles, 4-7 swap 679-643 comp. cam. high rise team g intake. eagle rodes an crank 14.5-1 compression. heads have been worked to the fullest by steve. nascar migul pistons 30 over. 400 stock chevy block 2 bolt main 1050 carb. i have been 5.87 at 114mph. 2560lbs car. can i get anymore out this combo. thanks
fast75vega 02-01-2011 04:50 AM
thats damn close to what were running and it will run 9.0's if we put the 4.88's back in it....... plus thats all throttle and no bottle...dont believe in poor mans horse power...... :wink:
smokinsmallblock 02-01-2011 05:11 AM
so thats bout all i can get out of it?
fast75vega 02-01-2011 06:19 AM
no.... if we get the new 245cc afr heads.......i know we will go even faster in the mid to high 8's or you can always put some go go juice on it.....lmao
hammertime 02-01-2011 10:00 AM
If you want to stay with 23degree stuff look into all-pro. You can get sb2 take off's at a good price, but would require a different piston also. But you'll gain a lot of power with that swap.
