7al3 question
how many out there had trouble with msd7al3 box and what were they?
They all have failures
If you use any electronic ignition, you will have eventual electronic failures. I have used MSD stuff for 25 years or better now and have had some bad boxes out of the package and some great for 10+ years. I do not believe that there is a known problem with any one box that MSD makes, but some can be damaged more easily than other models can. I will continue to use the 7AL3 on everything I run because I find them reliable and easy to trouble shoot in the field. I think that MSD is the best choice for Un Blown gasoline Drag Racing applications in my opinion.
As for what problems I have had, some miss fire at a given rpm, some stop firing altogether. For the most part they work or don't work or cause miss fire conditions. I have had two pro coils fail in 25 years and a few blaster coils fail as well. Bruce |
Re: 7al3 question
Ive never had a problem but know several who have. |
| All times are GMT -8. The time now is 06:44 PM. |
