-   -   converter question (https://www.racingjunk.com/forums/showthread.php?t=29759)
taps 02-01-2011 01:51 PM
converter question
what is a good #percentage wise for top end converter slippage?my beretta at 165 mph if you do the math should be turning 7300 rpm in traps but its turning 8000 rpm.
TopspeedLowet 02-01-2011 02:11 PM
4% in a good one to 7% on a greasy one. You are over 10% it appears.
Bruce
chevyfireball 02-01-2011 11:40 PM
According to three different calculators my Neal Chance aluminum convertor has 1% slip.
hammertime 02-02-2011 06:20 AM
2-4% is ideal, 6-8% is ok, 10% + isnt so great
fast75vega 02-02-2011 06:44 AM
converters are my kroptanite ...... never really understood them..... :oops:
how do you figure out your percentage?
taps 02-07-2011 09:53 AM
converter percent of slippage
you can use this formula trap speedxgear ratio x .336 divided by tire diameter should give rpm with no slippage,compare that with your rpm in traps to find how much your converter is slipping.
fast75vega 02-07-2011 10:19 AM
Re: converter percent of slippage
ok... cool.... thank you :D
