-   -   strange struts pss105 need to raise front end (https://www.racingjunk.com/forums/showthread.php?t=29837)
kmcclain 02-12-2011 08:01 AM
I have the strange struts spindal mount shaft mount, i need to rais the front of my car 1.5 inches, can i raise these struts or do i have to go to a bigger wheel or tire, or is there a quik fix?
johnracer 02-12-2011 08:19 AM
You can crank up the spring seats to raise the front end, but you'll lose most of the travel doing it. If you have a ton of power and don't need the travel you'll be fine. A taller tire is probably a better choice. The only other option would be to cut out the mounts and remount them lower to raise the front end and keep the travel......
Johnny
kmcclain 02-13-2011 07:27 AM
thanks
