Why do they
Why do they put wide white stripe on there slicks? Like in add 2131806 . :?
It's alot easier to see wheel spin.
TS1955 |
IT HELPS TO CHECK FOR TWISTING OF THE SIDEWALLS AT LAUNCH AND WHILE GOING DOWN TRACK --I WAS TAUGHT
you can use a camaro to see the movement in slowmochine . WE ALSO PAINTED A MARK ON THE RIM WHERE IT TOUCHED THE TIRE TO CHECK FOR SLICK MOVEMENT AROUND THE RIMS DURING LAUNCH |
you can use a camera to see the movement in slowmochine . WE ALSO PAINTED A MARK ON THE RIM WHERE IT TOUCHED THE TIRE TO CHECK FOR SLICK MOVEMENT AROUND THE RIMS DURING LAUNCH Thanks guys. I always was wonderinng that but never ask. :wink: |
Its cool to watch the launch on Fuel cars when they play it back in hi-def slow motion, the abuse those tires take is incredible!
Almost a must, for making chassis adjustments. good one with the camaro thing lively, i will use that one on my ford pals. :lol:
You don't need the stripe on a Ford. If you can't read the letters on the sidewall it means he's in the burnout or driving through his own oil.
| All times are GMT -8. The time now is 03:43 PM. |
