-   -   mufflers (https://www.racingjunk.com/forums/showthread.php?t=29876)
et7333 02-17-2011 06:37 AM
mufflers
I currently use flowmasters bullet race mufflers on my 68 camaro bracket car.I would like to make it quieter and use these mufflers.My question is do you think if I added pipe from the end of the muffler and exit it right near the front of the slick on each side would this quiet it down?
TheYellaBrick 02-17-2011 06:58 AM
It'll quiet down INSIDE the car but be a tad noisier OUTSIDE as more pipe will make a megaphone effect. If you want OVERALL less noise, it all depends on the mufflers themselves.
lively 02-17-2011 07:02 AM
it is not a good idea to dump the exhaust in front of the slicks--you know oil and spinning tires do not mix :oops: :oops:
things can happen--BE SAFE :lol:
ALSO- THE FARTHER BACK THE MUFFLERS THE QUIETER IT GETS--i learned that years ago on my street strip cars
dragonmaster093 02-17-2011 07:55 PM
shop im working at we just put 3 1/2 inch pipes on a 70 monte and mufflers are in front of rear end and tail pipes after slicks ( was a manderal bent kit) with flow masters on it sounds good too
