-   -   drag racing cam? (https://www.racingjunk.com/forums/showthread.php?t=29890)
mwbrasher 02-18-2011 04:32 PM
drag racing cam?
i'm building a 383 sbc for my vega... 5000 stall convertor.. turbo 350 .. foot brake car... no electronic.... 32x14 mickey tompson slicks 5.13 gears would a "dirt" cam work ???? it is a solid roller...642 lift ... 312 duration any help would be helpful.... thanks in advance.... :roll power band is 5800 to 8200
jmarksdragster 02-18-2011 08:54 PM
Duration will be too big for the converter, you would need closer to 6000 stall. Look for a cam with no more than 260˚ @.050 with the converter you have, it will run much better.
spib 02-21-2011 07:12 AM
check pm
JEFF69Z28 02-22-2011 10:19 AM
Re: drag racing cam?
1 YEAR USED COMP CAM I WILL SELL YOU.
WITH 1.6 ROCKERS THE CAM SPECS AS FOLLOWS
DURATION @ 50
INT.260,EXH.264
LIFT
INT.688,EXH.674
LSA 111
