Holley black and nitrous
do you think a single holley black could supply a 750 hp sbc and a cheater nos kit setup for 150 shot.
No I think that pump would have a hard time keeping up with the motor alone!
I run a black pump with roughly 600 hp n.o.s. has a separate blue pump |
I agree not enough pump, I run a holley black on my nitrous side alone.
Agreeded, not enough pump. We run 2 holly blues and 2 # 8 lines for a 468" pump gas motor with a 250 shot Zex plate.
JMO Zip. |
I have been using nos since early 80s and learn that if you have a high hp motor you need to run a seprate pump. When you run a deadhead pressure with out a return line you should flow the fuel jet you are going to use every time. Hope this helps.
Get yourself a Magna 500. It'll handle the lot.
| All times are GMT -8. The time now is 06:05 AM. |
