-   -   tire psi question (https://www.racingjunk.com/forums/showthread.php?t=30063)
taps 03-15-2011 02:37 PM
tire psi question
have a tube chassis beretta 2550 lbs 4 link strut front with 16-33-15 goodyear slicks,car runs in the very low 8 second range ,makes about 1000 hp any thoughts on rear tire pressure,i have been running about 7 psi.
BEAST477 03-15-2011 03:05 PM
You'll probably get a bunch of different answers on this. I would just keep going up 1/2lb at a time till your 60' times slow. Just make sure you use the same gauge as most will be different. JMO
TS1955 03-15-2011 04:14 PM
X2...Good advice!!!
TS1955
