9375-2 CARB
HOW CAN I TELL IF THIS IS AN --HP MODEL>>?? NEED TO CHANGE BOOSTERS .# :shock: 9375-2??
This is from jegs.com
510-0-9375-2BK Ultra Dominator Carburetor 1050CFM 3-Circuit 2 x 4 Carb Set-Ups Black View this item 510-0-9375-2RD Ultra Dominator Carburetor 1050CFM 3-Circuit 2 x 4 Carb Set-Ups Red It isn't a hp model :!: Mark |
9375-2
I thought HP is the new style casting verus the original style dominator in which case they look quite different. The HP series are all that have been made for several years and anything sold new by Jegs will be HP. Correct me if I am wrong.
I have used the 9375 with the annular boosters on single carb BBC applications with just air bleed changes. They do tend to go a little rich on top end though in 1/4 mile. The Ultra series is just billet metering blocks added and some updates. |
Yes that should be an HP carb. What is wrong with the boosters? www.blp.com has booster banjo's, stock or modified cast inserts as well as billet inserts and booster pins. Gaskets, screws, etc, anything else you need to rebuild one.
It depend's on how old the carb is if it is a HP or not :!: I agree the one's they sell now are all HP's :!: I have two 9375's and they are around 10 years old but they aren't HP's :!: Just standard Dominator's :!:
Mark |
| All times are GMT -8. The time now is 02:40 AM. |
