-   -   Bearing help (https://www.racingjunk.com/forums/showthread.php?t=30124)
sprint3 03-26-2011 08:58 PM
Bearing help
Cleaning out the shop and came upon a box of main bearings..they are new...top of box was marked 400sb ..but the end says ms829p BBC? I looked at the bearings and they are:5203 upper and 5202 lower. Rear main numbers are:6431 and 6432..the box says michigan 77 made in england...what the heck are these? Thanks!
markdunlap 03-27-2011 06:40 AM
bearing
BBC "P" production main bearings. Same as Clevitte bacically. Good for stock, mild performance rebuild. "H" is for high performance.
Tape them together in a circle and measure ID. Should be 2.750" approx.
SBC 400 is MS-1038. ID is 2.650" approx.
