-   -   1983 305 engine (https://www.racingjunk.com/forums/showthread.php?t=30196)
arkiesplace 04-05-2011 07:49 PM
1983 305 engine
I have a 1983 /305 engine and it will not start,it has good compresion,good spark and it is getting fuel ,it is not getting
any suction thru the carb and the timming is right on the money,I
am at my wits end can some one please help me find out why it wont
start or even fire .
Thanks in advance
[email protected]
mopar1968 04-05-2011 08:06 PM
Ok help us out is this a rebuild or you trying to restart a engine you had :?:
Mark
fla1976 04-06-2011 01:01 PM
Sounds like a timing chain. Does it backfire? Is the distributor spinning? Did you check the compression on all cylinders or a couple?
mopar1968 04-06-2011 06:10 PM
I agree :!: Sound's like might have either jumped time or gear in wrong :!:
Mark
TheYellaBrick 04-07-2011 06:39 AM
Didn't the 305's come with nylon timing gears ? Seems the high miler's always wore out the teeth, thus easily jumped time.
dragonmaster093 04-16-2011 07:00 PM
x2 dd they did
kbartley 05-02-2011 02:42 AM
1983 305
Lobes wore down on the cam & yep a nylon gear.
