-   -   carb spacer (https://www.racingjunk.com/forums/showthread.php?t=30215)
Moparmike55 04-09-2011 08:17 PM
carb spacer
I am looking for a carb spacer to run on my 360cid crate motor. Just install an Edelbrock air gap 7576 with a 750 Holley. May have to go to a ½” for hood clearance, is 4 hole, 2 hole or wide open the best.
Mike
mopar1968 04-11-2011 06:11 PM
I run a 4 hole spacer on my small block into a indy intake :!: :!:
Mark
fast75vega 04-11-2011 06:24 PM
Mark
now... why a four hole... s their really a difference? im running a open spacer with a 4 hole on top of that.
cncmotorsports 04-11-2011 06:32 PM
Every engine is different. Some like open spacers, some ported spacers.
Typically we see the 4 hole ported spacers work the best for most applications.
Hamburger makes a nice 1 inch ported spacer.
mopar1968 04-11-2011 06:39 PM
Mine is a ported 4 hole spacer. The bottom side of the holes are larger than the top of the holes.Engine was dynoed with spacer :!:
Mark
Moparmike55 04-13-2011 08:17 AM
carb spacer
Mark
Mark, Did you enlarge the spacer yourself or did it come that way, and who makes it? Thanks,
Mike
mopar1968 04-13-2011 10:57 AM
Here it is if you will look the hole's are tapered, It work's like a champ on my car :!: :!: The guy's that dynoed my engine worked to get me the best from the engine and found this plate work's great :!: :!:
http://www.jegs.com/i/Barry-Grant/13...oductId=743575
Mark
