-   -   65-66 396 (https://www.racingjunk.com/forums/showthread.php?t=30250)
Scorpion1110 04-17-2011 08:53 AM
65-66 396
Building an early 396. Need an early timing cover no dowel holes with tab for an eight inch balancer- Any of you guys got one laying around?
Scorp
fla1976 04-17-2011 10:26 AM
There is one on EBay. It doesn't state the size of the balancer. It is minus the dowel holes. There is over a day left on the auction.
http://cgi.ebay.com/ebaymotors/ws/eB...3653&viewitem=
wazup 04-17-2011 10:35 AM
Check out add#2160395 on rj. He has covers and some 8" balancers hope this helps.
stroked470 04-18-2011 12:26 PM
Dont forget to take the camshaft to a machine shop or someone with a lathe and have the rear journal grooved or you will not get any oil to the top of the motor.
oldandtired 04-18-2011 12:56 PM
If you matchup the cam with the cam bearings, you will be OK. The stock design cam had a groove in it. Stroked470 is correct - one of the two must have an oil passage.
Scorpion1110 04-19-2011 06:05 AM
Thanks- I had the machine shop take care of that, when they did the block and rods.
Scorp
