Adjusting the floats
i have a 406 sbc with a 850 quick fuel carb, i got the floats set 1/2 (middle)
of the sight glass. should it be set higher to the top (so when u shake the car, u then see the bubble) ??? i know 1/2 way would be ok on a street car but this is a race car only where do u guys set yours, thanks for the help. |
Remove plug and adjust so fuel is at bottom where it just barely starts to leak out.
Sight glass so no plugs. Is this gas or alcohol?
Curtis |
its gas & has the clear sight plugs......
If it is not pulling fuel over into the boosters at idle you should be fine.
| All times are GMT -8. The time now is 12:59 AM. |
