Price to build Ford 9 inch
What is the going rate to assemble a Ford 9"? I have a completely clean and stripped chunk with new master bearing set, new gears and new spool.
Thanks, Dave |
About $100 to $125 to set the gear up.
Around here $300-400
i guess i got out cheap, i just bought a 9" with new 513 gear and its already narrowed for 300. gotta love them crackheads.
:wink: Zip. |
i guess i got out cheap, i just bought a 9" with new 513 gear and its already narrowed for 300. gotta love them crackheads. I hope it was a buddy deal instead |
OK I may have confused some people.
Chunk assembly only - set pinion shim, press bearings, adjust backlash. |
$75 - 125 HERE YO GET IT DONE :lol:
Thanks, guys.
If I dissamble one, I can look at wear pattern, check shims and using math, calculate the new shim thickness from the old set up. This was a totally new set up and I don't own a depth kit. |
| All times are GMT -8. The time now is 04:24 AM. |
