-   -   sbc 9800 rpm's (https://www.racingjunk.com/forums/showthread.php?t=30360)
hotrod1994 05-08-2011 08:50 AM
sbc 9800 rpm's
i have a buddy telling me the garage built sbc he wants to build will be able to hit 9800 and hold up what do you guys think i personal say not a chance in hell nascar runs 9400-9800 and have tens of thousands in the engines
so what do you guys think
TopspeedLowet 05-08-2011 08:57 AM
that aint that high these days
Pro stock in NHRA turns there 500"BBC 11,000 plus at the stripe and a SB2 small block can easily handle 11,000 RPM for drag racing purposes.
What he is saying is not an unrealistic rpm for a SBC with a killer expensive valve train and non stock rotating assembly pieces including the block.
Bruce
hotrod1994 05-08-2011 09:54 AM
i dont doubt a small block can but not the way he is planning on doing it with the stock 2 bolt block he gonna use i dont think it's gonna hold up nor will the cheap parts he plans on useing
wazup 05-08-2011 10:55 AM
I wouldnt be standing by it when he turns it up. Sounds like a bomb. :lol:
fast75vega 05-08-2011 11:12 AM
X2 :wink:
482 05-09-2011 07:19 PM
It's for sure not going to do it long if, at all, with low buck stuff :?
Scooterz 05-10-2011 10:57 AM
I am not an expert here, but in a garage-built SBC on a lower budget I would focus on the max HP via the best power-curve you can get while holding together. In other words, not so much emphasis on high RPM necessarily. Why so much focus on the RPM if the torque curve & the longevity will suffer?
