-   -   Quick question (https://www.racingjunk.com/forums/showthread.php?t=30379)
Scooterz 05-13-2011 08:31 AM
Quick question
I am taking my 68 Chevelle to one more cruise in June b4 I yank the old 327 out & freshen her. This car is stock. Right now, If I get on it hard at Op temp, it fills the overflow & tries to puke coolant from the overflow tank. I have done nothing to this motor yet. I noticed it had a fresh w/p on it when I got her about 6 months ago. It is totally stock; except a mild cam. Runs cool... I wonder if the previous owner put in a high flow HD pump??? it looks stock. It is probably the small 2 core rad; manual trans. Whatcha think?
curtisreed 05-13-2011 08:36 AM
Bad head gasket or cracked head or cracked cylinder. Been there.
Curtis
Scooterz 05-13-2011 08:58 AM
That does make sense Curtis; hope it is not a cracked cylinder though. I guess I will find out! It burns oil some; not seeing white smoke yet however. It is time to pull it I guess. Should be an easy deal- no P/S, A/C, w/manual trans, no emissions crap, it is awesome. Take hood off, Just a few bolts here & there, a few wires, it is out. I guess I better get busy. It is incredible how inexpensive it is to freshen up a 327 engine!! Biggest expense will be the heads. Got a fellow drag racer dude at work that is going to help me with things I am not sure about. I have never completely gone through an entire engine before on my own. I will probably be bugging you guys at 12AM on here a few nights. LOL! scooter
curtisreed 05-13-2011 09:54 AM
You gotta watch those drag racers. You start out boring it to a 331 and before you know it, it will turn in to a 454. :lol: :lol: :lol:
lively 05-13-2011 10:56 AM
and narrowed rearend/ladder bars/ cage ____))0000--IT NEVER STOPS :lol: :lol:
TheRabbit 05-13-2011 11:17 AM
Yea, I started with a 454 and ended up with a dry sump 632 with NOS. Man "what was I thinking"?
Hope it's not to bad scooter.
Scooterz 05-13-2011 12:22 PM
LOL! I decided to keep this one a stock numbers matching car to retain the value. She is a virgin... Like that one good girlfriend you leave home on the weekends. I betcha we might be able to get her in the high 14's with a few minor mods.... a far cry from the fire-breathing beasts you guys saddle into.
TheYellaBrick 05-13-2011 06:24 PM
Head gasket and worn guides - tired rings.
billyd21970 05-13-2011 07:01 PM
dont take it to the track.stay away or you will be like one of use that got bit by the drag race bug..i started in a 15 second nova with a 307..and now i have a 10 second 92 camaro street car...lol
zipper06 05-13-2011 07:25 PM
Change the Thermostat to a 160, and put a new 16/18 lb rad cap on it. If you don't have a blown/leaking head gasket, it should not be blowing water into the overflow tank if the cap is good.
