-   -   1 TO 1 LINKAGE ON CARB (https://www.racingjunk.com/forums/showthread.php?t=30411)
JEFF69Z28 05-19-2011 04:30 AM
WHAT EXACTLY DOES THIS DO?
TS1955 05-19-2011 05:14 AM
Opens all four barrels at the same time. Not progressively.
TS1955
JEFF69Z28 05-19-2011 09:35 AM
WHAT ARE THE PLUS/MINUS OF THE LINKAGE?
zipper06 05-19-2011 08:36 PM
Totally depends on the engine configeration, Heads ,cam, exaust, etc. some engines will perform better with 1 to 1, a street engine will not.
oldandtired 05-24-2011 05:51 AM
x2 Race or boat application
TheYellaBrick 05-24-2011 07:12 AM
Are you talking 1-1 'carb linkage vs pedal action' or 'non progressive vs progressive' carb action ? 'Progressive' is the opening of the primaries to 1/4 throttle then slowly opening the secondaries at the same time as the primaries. 'Non progressive' is all 4 barrels together.
1-1 'carb to pedal' and 'non progressive carb' has serious 'street drivability' issues. Happiest at 1/2 throttle to wide open throttle.
