-   -   what to expect? (https://www.racingjunk.com/forums/showthread.php?t=30424)
cervidog 05-22-2011 04:15 PM
what to expect?
I installed lower control arm relocation brackets on my 80 malibu,Now Ihave to use adjustable lower arms to to put the rear axle back to stock location.I still am using stock upper arms,I am just wanting to know what to expect from this combo?
JEFF69Z28 05-23-2011 02:42 AM
Why did you relocate the lower control arms?
cervidog 05-26-2011 06:41 PM
The relocation brackets are supposed to lower the mounting point of your the lower arms to improve loading of the tires at launch.but now with the mounting point lower the axle has to swing forward to connect with stock control arms.when you do this it can cause your drive shaft yoke to bottom out on the spline of trams.
zipper06 05-26-2011 09:07 PM
Don't know what the situation is but you need 1 1/2 to 3 degrees on the drive shaft angle and need to have a min of 1/2" to 3/4" befor the yoke bottoms out otherwise you will destroy the trans..
