-   -   SNELL 2005 & 2010-- Whats the difference (https://www.racingjunk.com/forums/showthread.php?t=30430)
jreiley 05-24-2011 04:05 AM
I'm in the market for a new helmet. I see some vendors helmets are Snell rate 2005, some 2010, some both. Whats the difference? Are they both NHRA approved? Thanks.
fla1976 05-24-2011 12:15 PM
The obvious reply is 5 years.
The serious reply is on the website: http://www.webbikeworld.com/motorcyc...0-standard.htm
DRTRCR22 05-24-2011 04:09 PM
If you are racing, make sure to buy an SA helmet, NOT an M rated helmet. SA is for racing, M is for motorcycles. If you get teched most track inspectors will not let you race with an M rated helmet. Check the rules of the tracks and sanctioning bodies you plan on racing at. Most will only allow up to five year old helmets, but some have a transition period after five years.
If you are in the market to buy a new helmet make sure to get an SA2010, and do not be suckered into a sweet deal on a "close-out" 2005 model for a few bucks less. You may only get to use that 2005 for another year or two...
badrat1430 05-29-2011 04:32 PM
i think i read the sa has a higher impact rating than the m: M only good till 2014
