Thermostat for sbc with ali heads?
I have currently mounted the Edlebrock Performers on my sbc.After this upgrade about 2 weeks ago I am running a 160 thermo.I have not had a prob as of yet.There is much debate on what temp thermo should be ran on a street aluminum head.That a 160 will not let the engine reach its operating temp and cause the engine to have a short life.A fellow racer advised me to run a 160.
I have found via the net that ali heads run their best at 190 to 195 degrees and the oil will reach its operating temp to protect the engine. I had my engine rebuilt when I had the heads mounted.I just want to make sure not to crack a head or blow a head gasket or even worst. Any input is welcomed.Thanks.. |
Re: Thermostat for sbc with ali heads?
Hmm, let me get this straight, you want to raise the oil temps to help "protect" the engine, that's pure brillance right there dip chit! :? |
Hmm, let me get this straight, you want to raise the oil temps to help "protect" the engine, that's pure brillance right there dip chit! :? Well looky here Huckleberry, we got ourselves a bonafied redneck right cheer.... |
| All times are GMT -8. The time now is 07:50 PM. |
