-   -   SECONDARY LINKAGE SCREW (https://www.racingjunk.com/forums/showthread.php?t=30485)
JEFF69Z28 06-01-2011 02:32 AM
THERE IS A ADJUSTMENT SCREW ON THE SECONDARY SIDE OF MY CARB WHAT IS THIS FOR AND HOW DO I KNOW WHEN TO ADJUST IT IF NEEDED?
curtisreed 06-01-2011 03:46 AM
Are you talking about the secondary idle adjustment screw? If so it allows you to adjust the idle on a car with low vacuum/big cam, without uncovering too much transfer slot in the primaries.
Curtis
JEFF69Z28 06-01-2011 04:00 AM
INSTEAD OF RAISEING THE IDLE WITH THE PRIMARY ADJUSTMENT SCREW I CAN RAISE IT MORE IF NEEDED WITH THE SECONDARY SCREW.
900 RPM WITH PRIMARY & 200 MORE WITH SECONDARY.
hammertime 06-01-2011 04:05 AM
They are normally adjusted the same, if the primary is in say 4 turns, the secondary is in 4 turns also.
markdunlap 06-02-2011 06:52 PM
secondary
I like to take the primary to a minimum position and then adjust the secondary to get the RPM I want. I think the carb is more responsive off idle that way. Just my opinion.
