-   -   COOLING FAN (https://www.racingjunk.com/forums/showthread.php?t=30497)
JEFF69Z28 06-03-2011 03:38 AM
COOLING FAN
HOW MUCH CFM IS GOOD TO COOL A DRAG RACE ONLY ENGINE?
fla1976 06-03-2011 05:12 AM
Here is a site that will give more info. It should help decide the size you need. It also has info on flow, current draw and installation advice.
http://www.flex-a-lite.com/auto/html/electric-fans.html
JEFF69Z28 06-06-2011 07:38 AM
anyone heard of or used zirgo electric fans?they make a single blade 3000 cfm fan that draws 10 amps that im think about buying.
fast75vega 06-06-2011 08:37 AM
looks excatly like mine......i got mine 16" from autozone for $60 and come in sizes from 12",14" and 16"..... they are really thin and lite and move alot of air with not alot of current draw :)
JEFF69Z28 06-06-2011 08:49 AM
do you use a fan shroud?
fast75vega 06-06-2011 09:05 AM
no shroud.... just the fan and it will suck and hold a damn towel from a few inches away and keep it there..... i can only image with a shroud :)
TheRabbit 06-06-2011 12:35 PM
I use a Spal fan.
http://www.spalusa.com/store/main.as...&item=30102113
TheYellaBrick 06-06-2011 06:29 PM
Originally Posted by TheRabbit
DITTO here !
