-   GM LS engine talk (https://www.racingjunk.com/forums/forumdisplay.php?f=21)
-   -   ls1 cid (https://www.racingjunk.com/forums/showthread.php?t=30500)
jbpwrstroke 06-03-2011 06:52 PM
ls1 cid
What's the max did you can get out of a stock ls1 block?
fast75vega 06-04-2011 03:29 AM
you can get into the mid 390's... if you want bjgger then that you need to go to the ls2 block :wink: you can build a 408cid iron block for only a few hundred dollars difference but it also weights like 80 pounds more....lol
