FUEL PRESSURE
HOW MUCH FUEL PRESSURE DO I NEED TO RUN ON A 540ci CHVEY WITH BDS 871 STAGE 2 BLOWER WITH 2 1050 HOLLEY CARBS REWORKED BY CHUCK NUYTTEN I HAVE 85 PRIMARY 92 SECONDARY 37 NOZZLE I NEED HELP I CHECKED THE PAPER WORK THAT CAME WITH CAR AND IT SAYS 28 TO 32 lbs THAT SEEMS HIGH THIS IS MY FIRST ROUND WITH 2 CARB AND BLOWER SET UP STILL LEARNING :?: :?: :?: :?:
28-32 lbs should be actual pump pressure. But, you will need to regulate it down to about 8 lbs at the carbs.
TS1955 |
TS1955 |
| All times are GMT -8. The time now is 12:40 PM. |
