-   -   cam break in (https://www.racingjunk.com/forums/showthread.php?t=30569)
hotrod1994 06-17-2011 10:34 AM
cam break in
when doing my cam break in i know i need about 2000 rpms at about 20 min
can i just set the idle high and let it run or do i have to manualy do it with my foot
thanks logan
contagious 06-17-2011 12:09 PM
cam
If it's a flat tappet cam,I like to vary the rpm's and not let it stay in the same rpm range for a long period of time 1800 to 2500 or so.I if it's a solid roller,5 minutes bring up to temp,shut it down and check fluid levels,look for leaks and reset lash and timing.then straight to the race track.!!!!LOL
hotrod1994 06-17-2011 01:15 PM
ok it is a flat tappet thanks for the info
oldandtired 06-17-2011 02:40 PM
Re: cam
X2 FLAT TAPPET - Vary the RPM to get oil splashed up on the lower cylinder walls/ inside piston skirts. Solid rollers are broken in in 60 seconds / they work or they have failed.
bluedawg357 06-17-2011 05:06 PM
Dont forget to take the long bolt that holds the fuel pump rod in place and install the short bolt as a plug to prevent oil from spraying out the front of the block. learned that one the sucky way.
