does this make sence
Im was running a 7.25-1 sbc with a surcharges 12-14 lbs boost brodix track1 heads comp blower cam 575 lift solid roller the car went 10.20's rebuilt motor went to alcohol this year bumped compression up to 11-1 and 10lbs boost same cam and heads went almost same e/t and same mph 130
Supercharger sorry used my phone to post this and my phone likes to change my words
need more info on engine and vehicle...cam specs...the more the better...
its possible, you have more compression, but less boost.... hard to say how good your 'tune' is? |
Tube chassis 2500lb 355cu sbc bowtie block comp cam 12-704-8 255 262 @50 LS 114 575 575 solid roller turbo 400 4500 stall 3.89 gear 28-10.5 MT's changed from a 26cc dish piston to a 14cc dome piston 2 850 ken Jones alky crabs. the blower is a 420 mega blower 6% under
you gained the compression ive herd (compression gains abut 4% of hp per 1 point of compression like from 10:1 to 11:1 ) some say you gain from 10-20 hp depending on the engine itself but you lost boost you get about 10-20 hp per pound of boost depending on size and cfm of the supercharger so depending on the supercharger itself it may have just equaled each other out
sure your carb is jetted right for the alky? what temp you running? we were running mid 9.50's @ 160deg. ... jetted it down and got 180 temp and running 9.43's now
I know I have the crabs on the fat side I haven't been able to get back to the track to do some tuneing it was the first time out this year and just expected a little better performance but also had the timing locked at only 25 degrees total
bump timing up to 30 degrees total....then bump it up one degree at a time...don't go over 35...
watch your engine temps as others have said...don't go over 180 degrees |
I went from gas with 2 750's to alky with 2 850 ken Jones converted carbs A2000 pump boost ref regulator took the secondary jets from 79's to 85's both carbs figured better to start fat!
| All times are GMT -8. The time now is 09:04 AM. |
