hp estimate and estimated 1/4 et
sbc 350 stock bottom end 10:1 compression with
aluminum angle plug heads intake Port Volume 210cc Intake Valve Size 2.02 Exhaust Valve Size 1.60 lunati 60105 cam Advertised Duration : 284° /292° Duration @ .050 IN/EX : 241° /249° Gross Valve lift IN/EX .525''/.546'' LSA and ICL 110/106 RPM Range: 2500-6600 High Rise Aluminum Intake single palne 2500 -7500 rpm rang holley 750 Mallory hy fire 6 and Mallory unilight distridutor with msd blaster coil th350 stage 2 shift kit 2200 stall 4:10 gears and 29x12.50 m/t sportsman pro |
The intake runners seem a little large for a 350. What kind of heads and intake.
heres the heads there some e bay ones
http://cgi.ebay.com/ebaymotors/SBC-3...Q5fAccessories heres the intake another ebay http://cgi.ebay.com/ebaymotors/SBC-S...item5adc1d2b38 |
| All times are GMT -8. The time now is 02:36 PM. |
