-   -   Steering Shaft Help (https://www.racingjunk.com/forums/showthread.php?t=30614)
jjam 06-24-2011 05:35 PM
Steering Shaft Help
Can you use 3 u-joints in a steering shaft? This is a street car. The shaft will not clear the header unless I add another u-joint. Thanks
TopspeedLowet 06-25-2011 01:54 AM
yes
You can use as many as you can afford. Just be sure to use the bearing type and not the cheep pinned ones. The way you can tell is the cost on the good ones are about $75.00 each, Flaming river makes the ones I use. I use two 1/8" hardened roll pins on each end of the U joint to connect them to the 3/4" chrome molly tube.
Bruce
lively 06-25-2011 03:50 AM
Re: yes
Bruce
yep--using junk parts in the steering can have bad affects :oops: :wink:
fast75vega 06-25-2011 04:34 AM
Re: yes
Bruce
yep... here's a good example........ lmao
http://autoholics.com/2011/06/21/Dra...e-Strip-544241
jjam 06-25-2011 03:20 PM
Thanks, now this is another thing to remember also if your using more than 2 u-joints you might need a sterring stablizer... This will keep the shaft from the wobble... this will be installed next Thanks again
olds48 08-26-2011 08:17 PM
Use as many joints as needed.The more joints,and the more angle,the more steering resistance you will end up with.Just make sure each section of shaft between any two joints has its own support.NO FLOATING JOINTS!!!!
coolracing 10-31-2011 09:05 AM
Re: yes
One word WOW!
Bruce
