-   -   pontiac (https://www.racingjunk.com/forums/showthread.php?t=30641)
bsbober 06-30-2011 12:32 PM
pontiac
Anyone out there have some ideas about improving HP on a 76/350 f/bird w/2 brl,dual ex, auto???? Biggest bang for the least bucks of course. Down the road I should come across a deal on a 400 or something! I just want to get by w/what I have if poss. Thanks
fast75vega 06-30-2011 12:34 PM
just swapping the cam and putting a 4 barrel carb & intake on it will see a big gain for little money...... :wink:
bsbober 07-01-2011 06:25 AM
heads?
That sounds good! Approx what hp. would be gained?? Just a guess! Would more be gained by taking heads off and have them redone while doing the rest of this???And be worth the added cost??
TheYellaBrick 07-01-2011 07:03 AM
Any performance gain will depend GREATLY upon the condition of the base engine. Good compression/leakdown readings.
oldandtired 07-02-2011 05:47 AM
Re: heads?
Speed cost money, how fast do you want to go? :D
bsbober 07-03-2011 04:57 AM
If I get to a certain point of the upgrade and couple hundred more would make a big diff ,then I'm up for it !! For right now I'm not able to talk thousands $$$ I'm only looking for a few more Hp.
fast75vega 07-03-2011 05:11 AM
Re: $
like i said... you cant go wrong with a mild cam and 4 barrel carb/manifold and and a set off headers if you dont already have them..... :)
bsbober 07-03-2011 06:55 AM
headers
Thanks for the input ! The cam and carb sounds doable but the headers are a diff story. All the headers I've looked at so far indicates that one of the bolts have to be drilled and tapped for installation. I have the orig.manifolds w/dual flow-mstr now so would headers make a big improvement over this set-up?? If I need to drill/tap a bolt on the heads for headers, should I have something done w/heads?
bsbober 08-09-2011 05:32 AM
carb/intake swap?
HI ALL: I just put a new topic on about what intake and such I should go with as I have found a good carb and would like any info that I could get on swapping 2 for 4 brl. Thanks!!
