horsepower/tourqe and 1/4 mile est
355 sbc 4 bolt main high nickel block
12:1 compression afr eliminator aluminum heads 210cc intake runner 2.08 1.6 valves 65cc combustion chamber comp extreme energy 284 adv 284/296 @.050 240/246 .507/.510 lift 110 lsa weiland team g intake Holley 1050 dominator malory uni light distributor and hy fire 6 digital cd ignition it will be in a 76 camaro around 3500 lbs th350 3500 stall 28x10.5x15 m/t et drag slick on weld drag lights 4.56 gears -? what kind of rpm's do you guys think she turn across the line? thanks guys -logan |
Cam does not fit the rest of the combo - JMO.
CARB IS WAY TO BIG THAT THING ONLY NEEDS A 750 TO 850 CFM CARB.
| All times are GMT -8. The time now is 10:59 PM. |
