horsepower and 1/4 mile est
355 sbc 4 bolt main high nickel block
12:1 compression afr eliminator aluminum heads 210cc intake runner 2.08 1.6 valves 65cc combustion chamber comp extreme energy 294 @ .050 250 int./256 exh Advertised Duration 294 int./306 exh. valve lift with 1.5 ratio rocker arms 0.519 int./0.523 exh. 110 lsa weiland team g intake 850 cfm carb malory uni light distributor and hy fire 6 digital cd ignition it will be in a 76 camaro around 3500 lbs th350 3600 stall 28x10.5x15 m/t et drag slick on weld drag lights 3.73 gears thanks guys -logan |
Still got too much carb. It might run mid 13's.
ok so how big of a carb do you guys suggest
TS1955 |
I had a similar engine in my camaro actually less compression 10.5 and less cam and 64cc heads, with a 3800 stall in a powerglide and 456 in the rear car would go deadly consistent 12.09. Car weighed 3350, and the carb was a 4150 850cfm.
| All times are GMT -8. The time now is 11:00 PM. |
