12V to 16V Conversion
Hey Fellas...
Can anyone give me insight for a conversion. I presently have a 468 BBC with a 6-71 blower in my bracket car and I am considering a change to 16 Volt. What must I do to convert. Obviously I need to buy a 16 v. battery. Many people have converted because there must be an advantage. If it is too cost prohibitive then I may just stay with what I have. I am doing a complete rewire in my 55 Chevy for just drag racing. There are no wires left in the car and dash. All have been removed so I can do a professional installation. Thanks for any input!! |
The only thing you have to do is buy the battery and put it in. Once you do you'll wish you had done it a long time ago!
12v to 16v Conversion
It is not really that easy..... you still need a new charger for the 16V and have to update your alternator if you run one :lol:
Now it is that easy. |
12v-16v conversion
If you don't run an alternator make sure the battery is rated to be used without one. A friend of mine has one of the lightweight Turbostart 16v batteries and it doesn't give you any warning that it is running low. Start up head to the lanes, get ready for the round and nothing. We have found that that particular model is to be used only with an alternator. Don't know which ones are or aren't that way though, sorry I myself run 12v. Just a heads up.
Curtis |
Re: 12v to 16v Conversion
I've heard all kinds of stories about somebody knows somebody that had problems yata yata yata, but I've never seen it. In mud racing racing if you see somebody with a 12 volt battery you don't have to worry about him being fast!! :D I run the XS Power like this one http://www.summitracing.com/parts/XSP-S1600/ It also speeds up your fan, water pump and fuel pump so make sure to check you pressure after you install it. You can save about $100 if you buy the charger for 16 volt only, but I bought the 16 - 12 volt just incase I needed to charge a 12 volt. I put a new battery in my truck every year or 18 months at the most. I'm not gonna go to a race and have battery issues. You can also run a 16 volt alternator if you need to. Trust me you'll like it! |
I've heard all kinds of stories about somebody knows somebody that had problems yata yata yata, but I've never seen it. |
12v to 16v conversion
Thanks again Rabbit!! for the info Hey...."Tricks are for Kids"
Even with the alternator, make sure to check your charge. With the 16v stuff, when it's dead it is really dead. LOL. We give it a full charge at some point during the week or before going into the trailer when done for the weekend. We will charge it again after time trials and time permitting will charge it between later rounds.
| All times are GMT -8. The time now is 02:04 AM. |
