which dominator do i use
9375-1 or 8082-1.im running a single 4 barrel
Both need some metering work requiring tapping holes, either can be made to work well. Do you have either or both carbs or looking to buy? What are you putting it on? The 9375 should have removable bleeds, the 8082 not. 9375 is a 3 circuit and should have annular boosters, 8082 is a 2 circuit and probably has straight boosters. If I had the 9375 I would replace the metering blocks and make it a 2 circuit, the 8082 would get the bleed holes threaded for removable bleeds and annular boosters. Either way you have some work to do.
Designed for use on Drag race engines
Calibrated for a 1x4 setup Includes notched float and jet extensions Progressive Secondaries Dual 50cc accelerator pumps 2 Circuit Metering Calibrated for Gasoline Dual fuel inlets 4 corner idle Screw in air bleeds Annular Boosters Venturii Size 1.690 Throttle bore 2.000 Aluminum throttle plates this is how the 8082-1 comes out of the box according to the holley web page,the 9375 is set up fro useing 2 carbs. im going to put on my 406 sbc,i put a friends on last week and picked up 2/10's and 2 mph over my old carb set up from pro systems,840 CFM. |
They must be using the -1 designation for all of the HP 8082's, they list a -2 and -3 on their bleed chart but not the -1. If you are buying new, spend the extra for the Ultra 8082. It comes with billet metering blocks, all passages are threaded for changeable idle jets and emulsion, they also have external linkage which is easier to change secondary opening rate and has no internal linkage that can come apart. It will make it easier to calibrate for your engine. And if you qualify for the Jegs racer discount you will save about $100 on either the red or black version. And it looks pretty... :lol:
The ultra was want i was thinking about but the price,but a friend of mine deals with jegs and i pretty sire i can get his discount,was also thinking about an aed carb.
ULTRA 8082-2BK IS WHAT I SHALL PURCHASE WHEN I RETURN FROM VACATION,THANKS FOR HELPING ME MAKE UP MY MIND JMARK.
I have a friend who gets the racer discount! |
The parts in the Ultra are better than what would be in the lower end AED.
When you get it I can give you tuning tips if you need. |
| All times are GMT -8. The time now is 12:41 PM. |
