mixing fluids
just fitted a b&m deep pan to my t350, after searching here guy's are recomending to run 'f' type fluid. i have been running dexron III so the convertor still has a bit left in it, should i mix the 'f' type or keep using the dexIII.
mixing
Not quite on this subject, but does anyone use MOBIL 1 synthetic or Lucas synthetic trans fluid?
I don't think it will hurt mixing them together.
My trans builder always tells me to run Lucas, but I never have. I've used Red Line and Royal Purple and used the cheaper B&M trans fliud too. |
As everyone knows the Dexron fluid normally used by GM has a slipping agent, GM has never rccommended the type F because it doesn't contain the slipping agent, which Ford forever has recommended and shifts more solid. I've run Type F for over 40 yrs, in both racing and street cars and i've mixed them. I don't buy the special oils just OTC and i never use an additive like seal savers or anything else. I've tried the B&M and saw no difference from OTC's. I do use The VR1 in the alcohol engines, otherwise it's just OTC's.
JMO Zip. |
thanks guy's i think i'll try the f type fluid.
Re: mixing
Mixing will not hurt |
I bought a P/G from FTI and ask them what fluid did they want me to run in it and said type F do to it dont foam like other fluids.
Re: mixing
Mixing will not hurt TS1955 |
Amsoil also does not foam, a good fact if none of you have done this, fluids are a major deal on converter stall. You can tighten or loosen a converter with just a fluid change :) |
| All times are GMT -8. The time now is 05:44 AM. |
