old gas????
will old fuel cause an engine to hydrolock repeatedly, because it will turn over then stop pull the plugs itl turn again and then stop once u put fuel to it
It takes a LOT of liquid to hydrolock and engine. Maybe your timing is waaaay too far advanced ? Any gasoline dumping out of the plug hole after you pull the plugs ? You can bet your cookies that if you are getting THAT much fuel that it is contaminating the HECK out of your oil and washing down the cylinders and rings bigtime. |
ok il try retarding it and seeing what it does
| All times are GMT -8. The time now is 03:51 AM. |
