Dexron VI Transmission fluid
Can you use Dexron III transmission fluid when it calls for Dexron VI fluid? Are the fluids the same?
NO
Bruce |
dextron v1 trans fluid
what about using vI for III ?
What I have read in Gm's publications on transmission oil is that each newer number can be used for lower number fluids. Dextron 6 supersedes 5,4,and 3. You can use the recommended number fluid for the year or a higher number.
Bruce |
| All times are GMT -8. The time now is 04:29 PM. |
