-   -   cam grind help (https://www.racingjunk.com/forums/showthread.php?t=30883)
hotrod1994 08-27-2011 04:33 PM
cam grind help
ok guys im looking for custom cam grind suggestions for a sbc it has
9.3:1 compression and i want a high lift lift nasty sounding hydrallic flat tappet that will work with my set up
std bore 350
9.3:1 compression would like to run premium 91-93 octane
1.94-1.5 worked iorn heads
torker intake/ but i may upgrade to a knock off of the victor jr
holley 750 (yes it's a little big)
mallory unilite and mallory hyfire 6 ignition
it will have a th 350 behind it with a 3000 stall converter
4.11 gears
im looking for a high lift nasty sounding cam that will work good with my set up and make lots of power through from abot 2,500/3,000-6,000
im open to any help or suggestions
thanks logan
doorjammer 08-30-2011 07:13 AM
cam
look at comp cam.........thumpr cams
markdunlap 08-30-2011 02:49 PM
Cam
Just installed a Mutha Thumper Hydaulic roller in a 377 SBC street/Strip Nova.
It does sound REALLY GOOD at idle. Also has enough vacuum for power booster on brakes.
