-   -   do i need a mag? (https://www.racingjunk.com/forums/showthread.php?t=30994)
maxpower671 09-20-2011 08:19 PM
do i need a mag?
BBC427, methanol injected, nat asp. 1/4 mile drag,
do i need a magneto? :wink:
zipper06 09-21-2011 04:36 AM
Nope you need a MSD unit with, anything from a 6AL to a 7AL3 box. More fire power and less HP drain than a Mag.
maxpower671 09-21-2011 06:13 AM
do you run methanol and a MSD unit? which box? no problems?
ccperf721p 09-21-2011 06:43 AM
I run a 7AL2 with a pro power coil on a 15:1 alky injected 434. On a couple of occasions it has fired a 15% tip of the can without issues.
maxpower671 09-21-2011 06:59 AM
what sparkplugs? how much gap?
hammertime 09-21-2011 06:14 PM
With my 582 and alky injection, I ran a 6al, 7al2,7al3 and 7530t digital. No difference in et with any and they all did just fine.
maxpower671 09-21-2011 07:14 PM
thanks David....thats the kind of info i was looking for! gonna get my box checked out...
zipper06 09-21-2011 09:05 PM
NGK 8's set @ .024 gap, with a 6AL, same setting with 7AL2. I've never ran a 7AL3, so i don't know the difference.
ccperf721p 09-21-2011 09:49 PM
I run an autolite AR3934 @ .030
hammertime 09-22-2011 04:45 AM
AR3910s gapped at 30, Extended tip plugs, A lot of engines miss without them.
