496 bbc compression on pump gas
im looking to build a 496 bbc for my camaro and want to run pump gas what do you guys think about 11:1 on pump gas
block will get zero decked and i will use a 15-25 thousandths thick head gasket to achieve a good and low quench height it will be ran with aluminum heads also what do you guys think |
Thats NOT a Problem,but dont think you can Run 87 Octane and 38* of Timing!!
93 0r 94 Octane and keep the Total Timing in Check,and Let HER Eat!! Later G 8) |
11.0:1 On pump Gas (91 92 93 or 94? E85 definitely will), If you put the right cam in it. Look at it this way. Let's say you build it with 11.0:1 and it pings, so you drop the timing back to 30 degrees to get rid of the ping. You lost way more than you would gain if you would have lowered the compression ratio to 10.0:1 and ran 36 degrees timing.
Or you just end up having to mix race fuel to cover it up. I'm not saying it is not possible, just giving you some worst case scenarios that many people run into. Good luck with your build. |
I had 11.2 in my EMC motor all dyno pulls on 91 octane no pinging even down low I think it depends on your other parts selection and the rate that the timming comes in.
my concern would be the 0.015'' min piston-head clearance
Minimum of .035-.040 with steel rods. Aluminum rods need even more. Also need to check valve to piston. |
| All times are GMT -8. The time now is 03:23 AM. |
