-   -   What are you using to monitor your engine? (https://www.racingjunk.com/forums/showthread.php?t=31034)
efamous 09-28-2011 02:08 PM
I will be running a 421ci SB2 motor with Ron's terminator on alcohol.
Any suggestions.....
Thanks in advance.
482 09-28-2011 07:11 PM
I have a Computech egt plus if your just looking to monitor the EGT
Percy's is good too!
efamous 09-28-2011 07:38 PM
Thanks. Any of you SB2 guys care to chime in?
curtisreed 09-29-2011 03:39 AM
I have a data recorder from http://rpmperf.com/
Very easy to use and you can slowly build up the system one sensor at a time if you want. I don't have a SB2 but data gathering is all the same. For roughly $620.00 you can monitor engine rpm, drive shaft rpm, converter slippage, battery voltage and have one egt.
Curtis
outlaw256 09-30-2011 04:37 AM
technology, aint it great.i do it old school, oil temp and volts tach and a shift lite.that shift lite is as tech as i will go lolol
TheYellaBrick 09-30-2011 06:26 AM
Same here. I drive by the old 'seat of the pants' method. Eyes, ears, and butt.
:D
gearhead1011 09-30-2011 08:18 AM
I use a CompuTech DataPro 45. I really added a logger because of the clutch I run which I use engine, input and driveshaft sensors for that . I also monitor acceleration, EGTs, O2, oil pressure, coolant temp, vacuum and shock travel.
If you're looking at the CompuTech you can PM me for a price. I'm a full line dealer for them.
ajk 09-30-2011 12:06 PM
:D
Same here but in doing this i have found adding a engine diaper was a good idea..
TheYellaBrick 09-30-2011 03:23 PM
Diapers are a must as the 'engine' ages :shock: :shock: :shock: :oops: :oops: :oops:
I can certainly see how electronics can 'speed things up', but they just aren't my style for the occasional race I run. I'm a K.I.S.S. kinda guy.
efamous 09-30-2011 08:03 PM
Just trying to see what you guys are doing to get the best of your engines. I already have so much money in this thing, I'm almost afraid of it. Oh well they don't last forever do they!
