SB2 intakes
Anyone running a sheetmetal or tunnelram style intake on SB2 engine.
Looking for Pros and Cons. Thanks inn advance |
Hello SB2.2 guys? Where are you?
Depends on what you are after. Cast intakes can make really good power, Sheet metal make it easier to make a bit more on a single carb and needed for two carbs. Check this link on big power SB2's, only your checkbook is the limit.
http://www.yellowbullet.com/forum/sh...d.php?t=332758 |
Thanks Mark. Ive got my engine together already, just looking at getting the best that I can out of it . Without throwing away money chasing small incremantal et & mph. I've seen pictures but no data or claims from other SB2 guys on this or other boards.
| All times are GMT -8. The time now is 10:04 AM. |
