Picture Loading on Ad
Anyone else have issues loading pictures on your ad's ? Used to be able to just select several of them and load them all at once and now I can not. Only way I can get pictures to load is finish a ad without pictures and go back in and edit the media and load 1 picture at a time.
thanks :D |
posting images
What web browser are you using to post multiple images at a time on step 4?
You may have JavaScript turned off on your browser which would stop you from uploading all the images at once and you would have to go back the other way, one by one. pj |
I have the same problem, have not been able to make it work since it first changed. My Java script is enabled and I am using Internet Explorer, not version 8 or 9.
pj, put a ad up today, same issue still will not allow me to load all pictures at once. Any updates ?
talked to a few buddies they also have the same issue |
| All times are GMT -8. The time now is 04:04 AM. |
