tranny leak
My th350 is leaking tranny fluid from a hole infront of the lines for the tranny cooler. the holeis on the passenger side and is untapped and ive haad the tranny running before i just put a trans pak from b&m in it. i'm thinking of plugging the hole but not sure if its anything important. wondering if anyone has any ideas
Are you talking about the hole for the vent?
It could be i was going to just go ahead and plug and see what happens i started the motors to try to draw some of the fluid threw the tranny to see if i can add fluid now going to try later today hopefully works
If it is the vent DO NOT PLUG
the only vent i recall on the th350 was up on top behind the bell about half way back :wink: you sure its not the oring on the dip stick tube or the tranny kick down cable? does it leak when it sits or just when its running?
You are correct I was thinking powerglide. The vent for a 350 is on the drivers side at the base of the bell housing. Is there a kick down cable on this transmission, that would be located just below the fittings for the cooler lines?
yea it only leaks when i was just plain adding fluid i started it for 30 seconds to suck fluid threw the internals so im going to try again to fill it tomorow
| All times are GMT -8. The time now is 01:26 PM. |
