-   -   Front end question A Body (https://www.racingjunk.com/forums/showthread.php?t=31086)
Scooterz 10-10-2011 01:36 PM
Rebuilt the 68 Chevelle front end last weekend... (had lots of help; lol) did springs, shocks, tie rods, Idler/pitman, bushings (upper lower A -arms) etc... then did the wheel bearings. The car looks like it has BBC springs in it now.... but has SBC springs/SBC. Will it settle in some & come down some by itself? It went from low, low low to nose bleed.
fast75vega 10-10-2011 02:33 PM
yes it will most def. settle.... give it a few weeks :wink: did you make sure the springs were seated in the lower perches right too?
Scooterz 10-11-2011 04:27 PM
Yep... my wise friend actually made sure of that. I ordered SBC springs w/"AC"... but it is a non-AC car... thought they may have just a little more support... I figured this could be part of the issue... but even AC springs could not possibly make that much difference... I think?
fast75vega 10-11-2011 05:31 PM
if i remember right.... there is only 100 pounds diff in spring rating between ac and non ac springs :wink: i always went with ac springs too
wazup 10-15-2011 08:05 PM
Rigsby, did you tighten the A frame bolts with the weight, susp. on the ground. I allways tighten them up with the car on the ground, if not the car sits up high because the bushings are in a bind. I hope this helps.
fast75vega 10-16-2011 07:30 AM
thats a good point too :wink:
fast75vega 10-16-2011 07:31 AM
Scooterz 10-26-2011 04:20 PM
Nope... he did it on the lift. Crazy... I did not even think of that??? Always something new I learn from mistakes. I have kind of gotten used to it & it has grown on me some though... kind of an old school stance. Alignment seems good, goes straight, etc... front end ops up & down a little more now between gears since the old lowered springs were so short from being cut... almost 3".
TheYellaBrick 10-26-2011 07:39 PM
POST PICS !
pleeeeeeeez :) :) :) :)
wazup 11-09-2011 05:52 PM
I would look at the bushings as after awhile will start twisting the rubber out of them. I have had guys that worked for me and did them on a lift and i have them put it on a drive on lift and tighten all the bolts. I would also have the custmer bring the car back after about 500 miles and loosen all the bolts and retighten as the car will settle. Good luck and sounds like your having fun.
