-   -   Longest stroke in a Merlin block (https://www.racingjunk.com/forums/showthread.php?t=31087)
rrrdad 10-10-2011 02:44 PM
Just like it says. What is the longest stroke you can put in a merlin standard and tall deck?
Tod74 10-11-2011 02:22 PM
4.375 in the 9.8 deck 4.75 in the 10.2" deck
http://www.worldcastings.com/product...vrolet-blocks/
rrrdad 10-11-2011 04:36 PM
ok great... can a 632 be a wet sump?
michael1 10-15-2011 01:11 AM
You can actually put a 4.50 in a 9.8 deck but I wouldn't do it, Scott Shafiroff builds a 598 in a 9.8 deck block. Are you going with a block that has a raised cam?
hammertime 10-15-2011 05:03 AM
Actually you an put a 4.625 in a 9.8 and make a 615 APD does it all the time ;)
michael1 10-17-2011 09:42 AM
That's why I asked about a raised cam block, BES does stuff like that also. APD does alot of testing on all kind of stuff, they had a real good article a couple of years ago on some Big Chief testing that they did. I don't think APD gets as much credit as they should.
hammertime 10-18-2011 08:26 AM
Actually do not need a raised cam block. Mine is a 4.5 stroke in a 9.8 deck also.
That article was the start of a major change in cam profiles, the engine was a good friend of mine, he purchased from a big name builder and put a terminator on it. It developed the mystery "alky miss" and did not run nearly as well as it should of. APD was close so John Kyle did a bunch of work and figured it out with a cam he designed. They also have designed some of the best bbc heads on the market.
maxpower671 10-19-2011 08:20 AM
like to hear more about this 'alky miss'....is this the miss big inch alky engines develop...and a longer exhaust duration helps clean it up?? :?:
hammertime 10-19-2011 06:59 PM
There used to be a article on APD's website but they recently updated it and I can not find it. Maybe search the net for it. Should be APD and Big Duke Head. Exhaust duration is part of it.
michael1 10-21-2011 12:21 AM
That article is the reason that my cam has the specs that is has. APD did alot of testing with the 18* stuff.
