carb help!!
what kind of carb should i run i have a holley 750 and it's way to much carb motor sounds great but i think carb it too big due to lack of power it's pretty much gutless
should make around 325-350 hp or do i look else where for the problem its a sbc 350 i was think 600 or 650 what do i need or how much can i jet the one i have down and still maintain good idle and top end 6000 rpm 9.3:1 1.94/1.5 heads comp xe268 cam 477/480 lift edelbrock tourqer intake |
I run a 600 cfm holley, on pretty much the same set up, I came up with 583 cfm using the formula, I wouldn't go over 650 cfm.
Also your lack of power could possibly be from the cam not really matching the intake, good dual plane seems more a matched intake to the xe268h in my opinion.
ok thanks guys im thinking there is somthing wrong with the trans to it just doent move worth a dam but sound really healthy when idling and reved
| All times are GMT -8. The time now is 05:43 AM. |
