-   -   Out of round wheel (https://www.racingjunk.com/forums/showthread.php?t=31243)
ssym 11-14-2011 01:12 AM
Out of round wheel
I have 15x15 Weld Alumastar 2's. One of them has become out of round (for lack of a better word). You can just see the wobble when the wheel is on the balancer spinning. It still balanced with a lot of weight (4 strips of stick on's) and I don't have a vibration (hard to tell on the track).
Is there an economical way to repair this? Am I out $500? Or should I just leave it alone?
Steve
hammertime 11-14-2011 05:46 AM
Re: Out of round wheel
Steve
Did you put a run out gauge on them and spin them while on the balancer?
ssym 11-14-2011 06:43 AM
The shop guy used the sliding tool that measures the rim size. You could see the run out in-and-out and a little up and down. We ran the rim on the machine without the tire after it was hard to balance.
We did not measure it. I was in a hurry. Mounted the slick and I am running it now with the extra weight.
Maybe not a good idea?
hammertime 11-14-2011 07:54 AM
a LOT of times this happens and it just looks bad and measures good. Best bet is to measure the run out of the wheel only when you have time.
ssym 01-14-2012 04:09 AM
After getting a measurement the wheel is good. It was only the lip moving up and down about .125".
Tires are a little flat spotted because I let it sit on the ground.
Thanks for the thoughts.
